Periodic drop in frame rate (from 75-90 to 25-40 fps)
There are no ideas yet what this could be related to, there are only a few observations:
- Probably it is not related to graphic effects, since the frame rate drop occurs when the video card is loaded by only 75%
(I tried playing on low graphics settings - the effect remains)
- There is a feeling that the drop occurs at the moment of enemy respawn and during an intense battle.
I will continue to try to get rid of this effect, reducing all types of settings, including sound, upscaller, etc.
Update: after the last patch 15.11.2025 it simply became worse, and some new issues with upscaller settings.
Ryzen7 5800x / Gigabyte RTX 3060 ti
Drops in frame rate
Re: Drops in frame rate
Thanks for the report. Can you try disabling the Upscaler completely and let me know how performance is?
Everything is getting worse when upscaller is off.AmperCamper wrote: Fri Nov 15, 2024 7:14 am Thanks for the report. Can you try disabling the Upscaler completely and let me know how performance is?
After while I can say patterns are the same, mainly the frame rate drop occurs at the moment of enemy respawn, and also almost always near the helicopter on a new map.
Video setting seemed not involved, I've played at all low (GPU showed loaded only at 50-75%) and the frame drop still present.
In single player, everything is not as noticeable as in a network game in FUBAR mode, where the total number of insurgents reaches 135
Having already played for a decent amount of time, collecting feedback and feelings from players, I can sum it up - optimization is definitely needed.
Thanks for the additional details, GROOT.
If you haven't already, can you open a ticket with our Support team so we can collect your system specs and troubleshoot with you?
