Drops in frame rate
GROOT
Been thanked: 6 times
Drops in frame rate
Periodic drop in frame rate (from 75-90 to 25-40 fps)
There are no ideas yet what this could be related to, there are only a few observations:
- Probably it is not related to graphic effects, since the frame rate drop occurs when the video card is loaded by only 75%
(I tried playing on low graphics settings - the effect remains)
- There is a feeling that the drop occurs at the moment of enemy respawn and during an intense battle.
I will continue to try to get rid of this effect, reducing all types of settings, including sound, upscaller, etc.
Update: after the last patch 15.11.2025 it simply became worse, and some new issues with upscaller settings.
Ryzen7 5800x / Gigabyte RTX 3060 ti
Been thanked: 2352 times
Re: Drops in frame rate
Thanks for the report. Can you try disabling the Upscaler completely and let me know how performance is?
GROOT
AmperCamper wrote: Fri Nov 15, 2024 7:14 am Thanks for the report. Can you try disabling the Upscaler completely and let me know how performance is?
Everything is getting worse when upscaller is off.
After while I can say patterns are the same, mainly the frame rate drop occurs at the moment of enemy respawn, and also almost always near the helicopter on a new map.
Video setting seemed not involved, I've played at all low (GPU showed loaded only at 50-75%) and the frame drop still present.
In single player, everything is not as noticeable as in a network game in FUBAR mode, where the total number of insurgents reaches 135
Having already played for a decent amount of time, collecting feedback and feelings from players, I can sum it up - optimization is definitely needed.
Thanks for the additional details, GROOT.
If you haven't already, can you open a ticket with our Support team so we can collect your system specs and troubleshoot with you?
