hey, unless i am missing the most obvious setting, how to i change the default output device. I have a desktop speakers, a plantronic audio device for work, and steel series artic headphones. I cant see the option to set the output to the steel series artic headphones
Thanks
How to : Default Sound Device
Re: How to : Default Sound Device
Be sure to open your Windows settings (which will vary based on your OS) and make sure your default device and communication device is set to your desired piece of hardware. Once doing so, the game should pick up your device (you can verify to clicking on the arrows to cycle between devices in-game).
ah ! ok ; but, then i would need to chnage it back after the game ... but, thank you
