1. Mouse pointer on screen when you are using a controller. Seems to happen when you are downed and someone gets you up. Pointer shows up on screen gets stuck on screen like its the FOV DOT. Win key out then back in no help. Only way to fix is re-launch the game.
2. Healing thru windows. Not sure if this is a bug or by design.
3. Flashlight not coming on for either weapon after being 'revived' (spawning from the AAV). No repro steps. Just happens from time to time.
4. Commands not working over the Mic. When you hold in L1 (classic controls) and key UP for "Yes"/"Affirmative" the other players cannot hear it over the Mic, just locally. And even then its not very loud coming from the players voice box. And remove 'YUP' - no one is going to say that in country. Responses should only be: Roger. Yes sir. Affirmative. Copy.
5. Flashlight lighting. It is better but they still just don't luminate enough IMO.
Thanks.
Couple of bugs to report...
Re: Couple of bugs to report...
Thanks for the reports, chef.
- We're already working on #1.
- Can you clarify #2: is this Fireteam AI bandaging you while you're inside and they're outside (or vice-versa)? Or, are you clipping through windows when bandaging?
- Let me know if you get more repro steps on #3.
- I'm not sure if #4 if intended to be local VOIP or radio, but I'll check with the team.
- I've just let the team know about #5 with some other threads over the last week, too.
- chef_423
- Has thanked: 24 times
- Been thanked: 30 times
#2. If a teammate is down or AI, if I am on the other side of a window (open and broken), and I am inside the house and they are outside, I can still heal the User/AI if I press X on the controller.AmperCamper wrote: Tue Nov 19, 2024 6:56 am Thanks for the reports, chef.
PLEASE check on #4, just doesnt feel right. Those commands should be heard across the live Radio.
