Issue with Go Command (R1) Classic controller
chef_423
Has thanked: 21 times
Been thanked: 28 times
If you are zoomed into a location and you are pressing R1 to call out said location when you go back into your gun view it always sets it back to 'un-zoomed' (no scope) no matter what your setting is (last preference, etc)
Also, when you are hurt, get shot, to check a wound is very clunky and it needs work...I always end up sending a few Go commands before I start checking the healing issue, its spamming the Go Command to be honest. Need more detail there.
Thanks.
Been thanked: 2355 times
Re: Issue with Go Command (R1) Classic controller
Thanks for the report, chef. I'll take this to the team.
chef_423
Update here. A friend made me realize you no longer need to press a button to check your wound. So that is fine. But the pointing out a location then going back to scoped view should be looked at.
Thanks again
