Ever time i select my pistol and then pull up to use the iron sight I auto lean to the left, this is with the Auto lean function turned off.
any body else getting this?
regards
Joshua
Using the Pistol
Doc_Savage
- Has thanked: 14 times
- Been thanked: 8 times
Unknown0351
- Has thanked: 10 times
- Been thanked: 42 times
Doc_Savage
Re: Using the Pistol
I know he starts in a slight lean to the left, this is when raise the weapon up to use the iron sight he then leans left every timechef_423 wrote: Fri Jun 23, 2023 6:38 am Funny I do not. He does start in what looks like a lean when you switch to the pistol, but when you ADS its just straight on for me.
Im using a controller.
- Has thanked: 1349 times
- Been thanked: 2351 times
Can you guys let Support know you're seeing this? It doesn't look like everyone's running into this, so I'm curious how widespread this is.
