1. When I'm hosting, my mate will sometimes teleport somewhere far away on the map and then try to run back "in-bounds" but never makes it in time and the mission ends. This has NEVER happened to me as the host.
2. The reinforcement AAV is EXTREMELY slow and even though it gets on the map, the ability to respawn a mate is not present until after a LONG wait while the AAV inches brutally slow into some position on the map. This shouldn't be a thing to wait for. If you're giving us the ability to reinforce (respawn), heck you might as well just have the AAV appear out of nowhere. Waiting for it to be ready adds nothing to the game.
3. When I am the host, about 50% of the time, I cannot resupply. The icon simply does not appear. I tried both side of the AAV but no go. This has happened continually. My mates (who are not hosting) never have this problem - ever.
4. If you look straight on at a barred window, you see the bars. When you look a little to one side, the bars are replaced by a black window. Not a big thing but this is quite common .
5. The kill zone of the M203 grenade launcher seems much too small. I pretty much have to hit a tango on the nose to bring him down. When I put an M203 round into a small room, there should be no survivors.
Questions:
Can you kill a tango through a barred window? It feels problematic. I bet if I hit a barred window with an M203 round, it would do nothing to the tangos behind that window.
Some more issues (host-only and client-only)
desertjedi
- Been thanked: 23 times
- Been thanked: 2355 times
Re: Some more issues (host-only and client-only)
Hey jedi, thanks for reporting these.
- Have you noticed this happens more commonly on specific missions? Does this happen to you when your friend hosts?
- Noted on the second AAV.
- Is this referring to the first AAV, or second?
- Can you record a short clip of this one? I'm curious if you're friend is seeing the same as a client, or if you see it as a client when your friend hosts?
- Noted on the m203 blast radius.
desertjedi
1. I have no correlation to any mission. Seems to just happen at random. My friend doesn't host anymore so I can't confirm/deny.
3. It happens on ANY AAV.
4. I hope to get to it for you.
desertjedi
Some updates...
1. A friend of mine teleports whether he hosts or is a "client". This has NEVER happened to me so it could be related to his latency or something.
3. Whomever hosts has major problems re-supplying. As soon as my friend starting hosting, he immediately got this problem. I'd say it's even more than 50% of the time.
