Grenade Launcher
- NarcWahlberg
- Been thanked: 2 times
Grenade Launcher
Should the grenade launcher be able to destroy the tunnels? I have yet been able to destroy one with it.
Re: Grenade Launcher
The issue here is the time it takes for the grenade to activate. So, as annoying as it is, I believe they have it right here. Unless you can hit the tunnel from range that is.NarcWahlberg wrote: Fri Dec 29, 2023 12:56 pm Should the grenade launcher be able to destroy the tunnels? I have yet been able to destroy one with it.
- Has thanked: 1349 times
- Been thanked: 2351 times
Yes, this should work but there is a minimum arming distance for the m203.MRTINK wrote: Fri Dec 29, 2023 7:24 pm The issue here is the time it takes for the grenade to activate. So, as annoying as it is, I believe they have it right here. Unless you can hit the tunnel from range that is.
