HUD scaling issues on non-16:9 aspect ratios
krzy
Has thanked: 48 times
Been thanked: 35 times
I'm playing on a 5:4 aspect ratio monitor, and when using it's native resolution (1280x1024) a number of HUD/GUI elements ain't visible - displayed behind the physical borders of the screen. Those are left-side compass indicator, right-side vest/ammo count and the keybind menu.
Now, there is an option to switch to a lower resolution, but even on 16:10 aspect ratio (1280x800) compass and vest are clipping out of the screen a bit (although they are perfectly useable). The only resolution/aspect ratio that doesn't clip at all is 16:9 (1280x720), but on a screen like mine the image is rather small (enough that many other HUD elements, like vaulting/breaching key prompts are hard to read). It would be great if in future the HUD would scale/change position depending on screen aspect ratio.
Oh, BTW: after changing the resolution to lower, game won't allow me to go back to the native 1280x1024 - this option disappears completely (1280x960 being the biggest one), even though game had no problems (except that HUD) to run on that resolution. Can't say why would that be.
Re: HUD scaling issues on non-16:9 aspect ratios
There was a few widescreen resolutions we weren't supporting yet, but I'll add your feedback to the list.
As for the resolution bug, I'll forward this to the team. Thanks!
krzy
AmperCamper wrote: Wed Sep 06, 2023 7:43 am As for the resolution bug, I'll forward this to the team. Thanks!
In latest changelog I can see following fix:
Changelog wrote: Fixed an issue in which UI offset in certain resolutions
Indeed it seems that in-mission UI (compass, vest etc.) are now properly scaled for non-16:9 aspect ratios. Great, thank you! :D
However one menu - keyboard/mouse settings - still has elements displayed out of physical screen bounds. It's not as bad as before, but a bit of a bummer.
krzy wrote: Sun Mar 10, 2024 11:36 am However one menu - keyboard/mouse settings - still has elements displayed out of physical screen bounds. It's not as bad as before, but a bit of a bummer.
Making a note of this for our team.Thanks for the report and kind words on this!
