Changing graphic settings bumps up the frames
Posted: Sat Jul 01, 2023 6:22 pm
by Necramonium
So, i am sitting a set fps of 120, whenever i change the graphics when not in game (also in game), the lock is removed somehow and the frames get bumped up to the 300's and my CPU's fan go nuts. This also happened before the last patch, only thing to fix it is to quit the game and restart it.
Re: Changing graphic settings bumps up the frames
Posted: Sun Jul 02, 2023 9:31 am
by HaxRet96
You should limit your FPS count in Nvidia Control Panel or via Steam launch options (type command -fps_max 120).
Posted: Sun Jul 02, 2023 12:53 pm
by Necramonium
HaxRet96 wrote: Sun Jul 02, 2023 9:31 am You should limit your FPS count in Nvidia Control Panel or via Steam launch options (type command -fps_max 120).
Thats what i did.
Posted: Mon Jul 03, 2023 2:31 am
by HaxRet96
In this case, I would recommend to do clean GPU driver installation. With deleting all created profiles (settings). Because issue is on the Nvidia control side.
Posted: Mon Jul 03, 2023 1:46 pm
by Necramonium
HaxRet96 wrote: Mon Jul 03, 2023 2:31 am In this case, I would recommend to do clean GPU driver installation. With deleting all created profiles (settings). Because issue is on the Nvidia control side.
Well, than it's even weirder this is happening seeing i have a AMD card! :P
Posted: Tue Jul 04, 2023 1:03 am
by HaxRet96
Not sure about FPS capping in AMD Software. But GPU driver reinstallation is in the same manner. You can additionally use AMD Cleanup Utility to remove all files and setups, which may lead to issues.
