Marines sometimes turn black... Like black black... (BUG)
HatesThemselves
Has thanked: 12 times
Been thanked: 10 times
I think the screenshots explain this bug perfectly. ever since the new update marines have been turning under-the-bed dark, either due to a texture glitch or with lighting. This also happens to bandages, fingers and certain parts of the gun too.
Been thanked: 2355 times
Re: Marines sometimes turn black... Like black black... (BUG)
Thanks for this! I'll get this to the team.
What time of day were you playing on? Or, is this happening across several variations?
HatesThemselves
We didnt play any night or sandstorm missions during this. Also worth noting that this bug happened depending on where we were on the map which makes me think it might be a lighting issue (like how source lighting works)
We've identified an issue and expect to have a fix later next week.
Please note that this should only occur on Low graphics, and raising this should act as a temporary workaround until the patch (unless you're using non-RTX or AMD 5000x series GPUs - these aren't supported). For folks with these cards, the upcoming fix will be the solution.
HatesThemselves
Yeah, I had a feeling this might've been due to low graphics. I might try higher graphics especially after the recent performance fixes
thanks for the help, Amper!
