I'm starting to play with AI, especially because sometimes im just unable to find people, so i will be reporting ai bugs here when I can.
Your AI teammates will never heal you if you issue a suppress or watch order, just leaving you to bleed out. You are also unable to give any orders when you are incapacitated so you cannot tell them to cease fire. This goes for the ready as well where if you have a watch order he will just never help you.
AI not healing you bug.
- HatesThemselves
- Has thanked: 12 times
- Been thanked: 10 times
- Been thanked: 2355 times
Re: AI not healing you bug.
Yes, being unable to issue commands while incapacitated is intentional. But, they should react to your player state and revive you (there are cases where they prioritize incoming fire, though).
We're bringing a bunch of improvements to this area with our next update, coming mid-April.
- HatesThemselves
Thanks amper!
Also one more note if you dont mind, when the ready is active he's the only one that can heal you, issue is, sometimes the ready is across the map not doing anything, therefore you're left to bleed out by the two teammates that are right next to you, this might be fixed by making whichever AI is safe and closer to you able to heal you, are you able to notify the ai devs about this?
Thank you.
Thank you.
Absolutely, thanks for the report. I'll check with them in the office tomorrow (it's likely we're already aware of this).HatesThemselves wrote: Sun Apr 06, 2025 2:08 am Thanks amper!
Thank you.
