Mark IED's
Has thanked: 125 times
Mark IED's
The secondary mission is to mark the roadside IED's but if they are set off, the mission is unsuccessful. It would be much clearer if the objective stated to prevent the IED discharge. It sucks marking the IED then a spotter sets it of and all that work was for nothing.
Re: Mark IED's
Are you suggesting a change in the way the objective is listed, to be more accurate?
Re: Mark IED's
AmperCamper wrote: Fri Jun 07, 2024 12:32 pm Are you suggesting a change in the way the objective is listed, to be more accurate?
Either list it differently (prevent IED detonation) or make the objective a success if the IED's are marked regardless of detonation. Either way will work but as it is now, it is very confusing. The first would mean that you would be able to be successful without marking them just by avoiding them. The second would be a success even if detonated as long as hey were marked. If you want them marked and not detonated, phrase it that way (mark IED's and prevent detonation).
