Update causing me to disconnect after finishing a match and going to the lobby
rdawg420
Been thanked: 29 times
When finishing a mission and going back to the lobby, I get the message "authenticating...." then it disconnects me. Never had this problem before the update. Happens every time. It doesn't happen when retrying a mission though. I also uninstalled and reinstalled the game and that didn't help. Any idea how to fix this?
Re: Update causing me to disconnect after finishing a match and going to the lobby
Thanks for reporting this. If this is happening consistently, are you able to share video of the issue you're describing?
rdawg420
Here's a video. Happens every time I quit or the match ends to go back to the lobby. https://streamable.com/1lvv1i
Lykos
Has thanked: 18 times
Been thanked: 13 times
This happens to me too almost every time .. If I click switch to wargame or return to lobby
https://streamable.com/8s9q3g
Are you guys still experiencing this issue?
Lykos
AmperCamper wrote: Tue Jan 09, 2024 11:04 am Are you guys still experiencing this issue?
Yes
rdawg420
Yes always
Thanks for letting me know, guys. The video links you've shared have since expired. Is it possible to reupload these for us?
Since it was close to the holidays, I missed the earlier posts.
rdawg420
AmperCamper wrote: Wed Jan 10, 2024 8:11 am Thanks for letting me know, guys. The video links you've shared have since expired. Is it possible to reupload these for us?
https://streamable.com/hxcq4x
rdawg420 wrote: Wed Jan 10, 2024 11:49 am https://streamable.com/hxcq4x
Thanks for sending this! I want to clarify that this not only happens when manually leaving missions but also after mission completion? The clip only demonstrates the former.
