Video with some bugs - IED, Mortar and ADS
https://clipchamp.com/watch/quILnUjxzC6
IED - After disarm, it keep beeping and blinking. No animation to disarm. I would that happens 30% of times.
ADS - Not my mouse, i can guarantee that. If I use hold to aim, it's unlikely to happen.
PS.: Performance is way better after Wargame Update. On Sniper mission, which always had the worst performance, I don't have the huge dips anymore. Now 65~70FPS+ all the time.
It also improved performance in other missions, much more stable.
Re: Video with some bugs - IED, Mortar and ADS
Huge thanks for reporting these.
IED interacts are still being tracked on our known issues, so hang tight on this.
As for being unable to ADS with the m203, can you walk me through a step-by-step repro for this? I see the video, but it'd be great to get a walkthrough just to be sure.
AmperCamper wrote: Mon Sep 18, 2023 8:30 am Huge thanks for reporting these.
Thanks!
I usually use Toggle ON for aim. This does not occur when it is turned off. But not always happens when it's turned ON. When it happens, it lasts all the match. If I turn Toggle OFF, it starts to works fine againg. If I turn Toggle ON again, the problem returns. So it only ends at the end of the match or by turning on the toggle.
It also happened with normal use of the rifle, but it no longer occurs. Maybe a update have fix it for rifle (not M203) or I'm being just luck now.
