It feels like the ammo capacity of the combat shotgun in six days seems kind of low. I looked up what the marine corps uses, and they use the M1014 which is the military version of the Benelli M4. It has a tube capacity of 7 rounds, plus 1 in the chamber, plus an additional ghost load round for a total of 9 rounds. Right now with the 6 round capacity and lowering the weapon while taking fire makes this weapon seem extremely ineffective in close quarters.
Benelli M1014 Capacity
scubasteve04
- Been thanked: 3 times
Moysturizer
- Has thanked: 7 times
- Been thanked: 1 time
Re: Benelli M1014 Capacity
So standard load is:
6 shells that are -3 inch
OR
7 shells that are ~2.75 inch shells
Going from the 6 (3") to 6+1 seems easy and quick enough, but the +1 ghost load and then the +1 chambered seems hard and time consuming in combat. Fiddling around while in a hostile zone for the ghost load seems a poor use of time when your squad is depending on you. I worry there will be a lot of players obsessed with having 6+1+1 all time from past personal FPS behavior.
OR
scubasteve04
The marine corps use 2 3/4 inch shells, so that is 7+1 is a standard load. Ghost loading is unwieldy but still doable before you enter combat. 6 round total capacity in game (5+1) is the civilian M4 capacity.
Game needs to have an 8 round capacity, and I you want to model ghost loading, then have you start with 9 total and only able to reload normally up to 8.
- Has thanked: 1307 times
- Been thanked: 2344 times
Hey guys,
Apologies for missing this. Let me circle back to the team with this feedback. Thanks!
"doable before you enter combat" implementing a "ghost shell" mechanic that will only be relevant at the start of a round seems like a waste of dev resources tbh. I do agree the shell load should be upped to 7+1.scubasteve04 wrote: Sat Aug 26, 2023 10:44 pm The marine corps use 2 3/4 inch shells, so that is 7+1 is a standard load. Ghost loading is unwieldy but still doable before you enter combat. 6 round total capacity in game (5+1) is the civilian M4 capacity.
