Changing graphic settings bumps up the frames
- Necramonium
- Been thanked: 18 times
So, i am sitting a set fps of 120, whenever i change the graphics when not in game (also in game), the lock is removed somehow and the frames get bumped up to the 300's and my CPU's fan go nuts. This also happened before the last patch, only thing to fix it is to quit the game and restart it.
- HaxRet96
- Has thanked: 2 times
- Been thanked: 12 times
Re: Changing graphic settings bumps up the frames
You should limit your FPS count in Nvidia Control Panel or via Steam launch options (type command -fps_max 120).
- Necramonium
Thats what i did.HaxRet96 wrote: Sun Jul 02, 2023 9:31 am You should limit your FPS count in Nvidia Control Panel or via Steam launch options (type command -fps_max 120).
- HaxRet96
In this case, I would recommend to do clean GPU driver installation. With deleting all created profiles (settings). Because issue is on the Nvidia control side.
- Necramonium
Well, than it's even weirder this is happening seeing i have a AMD card!HaxRet96 wrote: Mon Jul 03, 2023 2:31 am In this case, I would recommend to do clean GPU driver installation. With deleting all created profiles (settings). Because issue is on the Nvidia control side.
- HaxRet96
Not sure about FPS capping in AMD Software. But GPU driver reinstallation is in the same manner. You can additionally use AMD Cleanup Utility to remove all files and setups, which may lead to issues.
