Firemode Prompt
scottysmacc
Been thanked: 9 times
Firemode Prompt
Currently, I don't believe there is a way to tell what firemode you are currently on aside from firing your weapon.
I believe implementing a keybind, (like holding down the firemode key) to display what your current firemode is would be useful.
This may already be implemented, I apologize if it is.
sebas2289
Re: Firemode Prompt
You can check what fire mode you are in by looking at the center of the screen. If it is a single dot single fire, if it is 3 dots burst or auto.
But I do agree there should be a bigger indicator, because those dots are quite difficult to spot
StrixBit
Been thanked: 7 times
Re: Firemode Prompt
If you're like myself and other and have crosshair off, it won't display. I'd be down for audio indication, with an icon hiding in hud. However, people with no hud would suffer, if swivel for the head was added you could look down and see the selector switch in the correct position. I could also see that when you hit it, maybe your guy does a 1 sec glance downward to verify. Either of these would be good for those playing without visuals.
Re: Firemode Prompt
StrixBit wrote: Sun Jun 25, 2023 9:09 pm If you're like myself and other and have crosshair off, it won't display. I'd be down for audio indication, with an icon hiding in hud. However, people with no hud would suffer, if swivel for the head was added you could look down and see the selector switch in the correct position. I could also see that when you hit it, maybe your guy does a 1 sec glance downward to verify. Either of these would be good for those playing without visuals.
Yeah, this. Don't like crosshair in games when it useless (since you're not shooting where the cross is). So I need to shoot and spent bullets to know what firemode i'm using. We need a feedback.
KageOni
Been thanked: 14 times
Re: Firemode Prompt
A little selector switch could display with the hud that shows your rig/remaining equipment showing what position it is.
EVILGUNZ
Has thanked: 3 times
Re: Firemode Prompt
hate holos I think this would be reasonable because I should be ablle to at any point know if my weapon is on safe, single or burst without leaving ads or point
MILLER_gear
Has thanked: 11 times
Been thanked: 6 times
Re: Firemode Prompt
I usually press the "check magazine" option to see the position of the fire selector on the M16.
I'ts stupid, I know... but it's the only way I have to check it (I play without crosshair).
Re: Firemode Prompt
Thanks for all the comments on this. I'll take this thread to the team for review.
