Game Brightness Issues
yasil
So whenever I play fire missions solo or with team mates my brightness will suddenly go down and the screen gets dark. I have to go into the setting mid game and reset the brightness everytime. Happens probably every 5 minutes or so. I was just wondering if anyone else has had this issue and if there is a way to fix it.
Re: Game Brightness Issues
I'm very curious if anyone else is experiencing this issue. Please restart your Steam client and report back for us.
Alternatively, you can open a ticket with Support if you haven't already.
Petrograd
I have the same issue.
Screen becomes darks sometimes black directly and always when I talk via radio, it fading black until total black.
I have to go to settings > brightness and it reset it.
Petrograd wrote: Tue Jun 27, 2023 11:33 am I have the same issue.
Can you verify that the brightness setting drops really low on it's own, and you have to manually reset this? When does this happen during gameplay? Does this happen every time?
HaxRet96
Been thanked: 12 times
Some AMD cards have got a fuction called 'Vari-Bright' that may lower screen brightness in order to save energy. Maybe you should check this option if you use AMD card. Not sure about dynamic brightness in Nvidia Control Panel or Windows settings. But you should check it as well, to make sure if game or system settings cause this.
Additionally - do you have Steam cloud enabled for Six Days? So the game can use previously saved settings without problems (like brightness).
