Using the Pistol
Doc_Savage
Has thanked: 14 times
Been thanked: 8 times
Using the Pistol
Ever time i select my pistol and then pull up to use the iron sight I auto lean to the left, this is with the Auto lean function turned off.
any body else getting this?
regards
Joshua
Unknown0351
Has thanked: 10 times
Been thanked: 42 times
Re: Using the Pistol
I have the same problem
chef_423
Has thanked: 24 times
Been thanked: 29 times
Funny I do not. He does start in what looks like a lean when you switch to the pistol, but when you ADS its just straight on for me.
Im using a controller.
Doc_Savage
chef_423 wrote: Fri Jun 23, 2023 6:38 am Funny I do not. He does start in what looks like a lean when you switch to the pistol, but when you ADS its just straight on for me.
I know he starts in a slight lean to the left, this is when raise the weapon up to use the iron sight he then leans left every time
Has thanked: 1357 times
Can you guys let Support know you're seeing this? It doesn't look like everyone's running into this, so I'm curious how widespread this is.
